Rear and front wheel bearing part numbers??
Buttocks
Post by Buttocks »
Does anyone know of the part numbers for the rear and front wheel bearings or are they fairly universal and can be obtained anywhere?
scarecrow
Post by scarecrow »
http://www.completefto.com.au/FTO_showcontent.asp?hid=84
MB303865 - Bearing
MB303868 - Wheel Bearing Kit (Front)
Camskill.co.uk - Bearing, Wheel (Rear)
I'll have a scratch through the parts database. I gaurantee they are common with other Mitsi models - I also gaurantee they would be a generic size & type you could buy from any industrial bearings suppliers like CBC bearings....
Bearings
Have looked up the Mitsi Parts DB I have.
The parts for the front Bearing Scarecrow mentioned above are right (The top one is the bearing itself). The rear bearing does not have a part number listed for the bearing alone, you seem to have to buy the Hub Assembly. The Part number for this is either MR131217 or MR316500, depending on the model of your FTO. The first of the two seems more common.
[edit] NOTE: Just noticed that the part number listed against the bearing kit above is not for the whole kit, just for the split ring within the kit. Have updated the Complete FTO Site to reflect this change. Sorry for the inconvienience.... The bearing kit probably does not have a part number as such, is likely that Camskill sell as a set
    Updated
    Just updated Complete FTO with a breakdown for this - follow URL and then click on the dots to see the part details
    http://www.completefto.com.au/FTO_showcontent.asp?bid=100
    and
    http://www.completefto.com.au/FTO_showcontent.asp?bid=102
