Actually, this is something I too am interested in as it really does give the car classier look as opposed to the massive chrome tips that are attached to most name brand exhausts.
I guess a problem with the FTO is that the exhaust runs up the left hand side of the car and then banks to the right before turning towards the rear of the car.
If you were to run a split setup from the cat you'd have to find somewhere to run the second pipe too otherwise it'd be running parralel to the current piping. If you do it from the muffler, the gasses will always choose the quickest way out, which would most likely be the to left.
It's definately doable, but whether or not it really adds any advantages apart from looks hasn't really been discussed.
Kazbah has it, maybe we should get her to crawl under her car with a camera!
EDIT: Plus you'd have to cut and respray your rear bar to allow for the second set of tips to fit properly.
I wonder what it would look like with twin tips coming out of the central part of the car??
