FTO - Hydraulic or cable clutch?
- spetz
Someone told me ALL FTO's were hydraulic clutch?
Now, I drive a lancer with a FTO engine/gearbox and it is cable clutch.
Can people check their cars and let me know which one they are?
Thanks
Thanks
- devil2004
Re: FTO - Hydraulic or cable clutch?
I'll check for ya, but how you tell the difference?spetz wrote:Someone told me ALL FTO's were hydraulic clutch?
Thanks
- spetz
- devil2004
Yeah both master & slave can be reconditioned depending on how badly worn the are. You can run a small hone through the bores of the units & put a new seal kit in them. Sometimes, if they are too badly worn, you just have to swap them out.
Technically, being a hydraulic clutch - the engagement point of the clutch plate itself cannot be changed - however, you can adjust the pedal postion of engagement. Where the pedal assemble attaches to the master cyclinder - there is a threaded section on the bottom of the master. Just undo it & wind in or out, then re-assemble. There was another thread on this somewhere which had pics too....
Or you can get the workshop to put in a S/S sleeve.Bennoz wrote:Yeah both master & slave can be reconditioned depending on how badly worn the are. You can run a small hone through the bores of the units & put a new seal kit in them. Sometimes, if they are too badly worn, you just have to swap them out.
BobZ
Jeeze you musta got a good guy at Northshore Mitsi... they wanted to charge me over $400!
Just send an email to Mike Ashton at Kempys & he'll sort you out
mike@kempys.co.nz
mike@kempys.co.nz
