spark plugs covered with oil
- robsta
i done a spark plug change last weekend and some of the old plugs were covered with oil, im assuming this is not a good thing. any ideas what needs to be replaced?
Erm... yeah... Oil on plugs is bad.
Things that can cause that? Worn piston rings, shot valve seals & valve guides. All pricey items to repair.
I would put new plugs in & see if they come out looking the same. If they do - then at least you can pin point the cylinders that are doing it. Then you can get compression tests done on those cylinders. Does it blow any smoke out of the exhaust?
Robsta,
One of the main reason having oiled spark plugs is having too much oil in the engine.
Check your oil level immediately.
If too much get rid of some asap, and make sure to recycle the oil.
It is not funny anymore that how many time after servicing I had to drain the excess oil myself.
I have serviced my FTO in many Mitsubishi services, and with Lee in Melbourne,
Always had way too much oil put in.
One time I remember the oil level was about 2-2.5 cm above the max line.
