FTO Workshops in QLD
- FtoSam
I remember on the cruise jeff and a few other guys saying about a workshop that has an FTO mechanic?? What was the name of it again? Contact Details?? And Will.. did your mate get the details for the guy that does the mag wheels??
- HiRAEdd
- HiRAEdd
Dan,I need someone to change my heater core again. I cbf doing it myself this time.
I got Jo and Riks to do mine as they sourced me a second hand heater core super cheap from one of their wrecks.
Only problem was that they fitted it at their normal leisurely pace.
Was about $500 all up including core from memory (well, it was a while ago)........they did it the hard way by pulling out the dash and releasing the aircon gases etc etc.
BTW what do you know about clutch slave cylinders? getting mine replaced on Friday, seems to be another "common" FTO fault.
Cheers
Chris
timing belts
Yes well I got Rik's to change my timing belt difference between quote and money I had to fork out was over $200 in their favour I'm up for a new timing belt in about 40,000K's that's less than 9 months so I'm starting to look else where
- HiRAEdd
Drift king
Ok thanks will look them up Will be changing belt again because nearly 100,000 K's since it was done Hope that clears confusion
- HiRAEdd
