does any one know where i can get a cheap short shift??
is it worth putting one in?
i test drove my friends dc2 and the gear is soo much shorter and seem quick to shift..
or is there a modification we can do to make the shift shorter?
thanks
know any cheap short shift?
- hnm738
Whatever you do, dont cut the stick.
I've got a C's quickshifter & its brilliant. Available thru www.perfectrun.com.au
Couple that with this little fix:
http://www.ftooc.org/phpbb/viewtopic.php?t=47584
And you have the sharpest changes in town.
RPW also do a good quickshifter as well.
- Mitsiman
RPW can modify the shifter to our normal short unit or a rally spec mega short shifter.
But we had two exchange ones, and the customers never bothered to return them back so we now have no exchange ones left.
We only need the shifter for around 3 hours so if you want one and can do without the car for 3 days, send it to us air freight Australia post and we can modify it and send it back the same.
Garaunteed you won't be disapointed with the results.
