Hay all, im new to this forum, i dont actually own an FTO but i keep my sistas running in top form. The other day i was checking the fluids and stuff, and her power steering fluid is quite low. Im wondering what should i use to top it up? Would it be the same that my MkIV Supra uses, castrol dexron III ATF??? Or does the fto require sumthing different?
Cheers
FTO Fluids
- MADFTO
Honestly I don't even know whether I should be posting because this advice has no knowledge backing it.
I suspect any standard power steering fluid would work with the FTO. Power Steering is basically the same across most cars AFAIK. All cars would deal with roughly the same amount of stress however, I could imagine FTOs having less stress to deal with compare to say a Commodore due to weight.
As I said, don't take my word for this because I have never actually found out about this, I've always though standard fluid would work.
