Not enough...
- demonic_hordes
Not enough...
Ok, so I'm at the red lights, ready for it to go green.
Bam! i'm off. rpm rises 5...6...7 shift
5...6........
and the car begins to shudder. it seems that the car is not burning fuel quick enough or something like that. its not like the steer wheel is hard to control or anything but more like the acceleration switches on and off.
What do you guys think is the problem? what kind of fixes are there?
5...6........
- kazbah
- National Secretary
- sublime19
- Sooty!
definately sounds like u didn't let the engine warm up, I'm not an expert on engines but one thing I DO know for a fact is NOT to rip the sh*t out of your car unless you have driven for at least 10 minutes.
Correct me if i'm wrong here
- khunjeng
Re: Not enough...
obviously u hit MIVEC already and it does this in 2nd?? new spark plugsdemonic_hordes wrote:Ok, so I'm at the red lights, ready for it to go green.
5...6........
now seriosuly ... can u tell us anything else aboutt he situation??
- khunjeng
- demonic_hordes
it has happened before. but in the case of this morning, I let the engine run from a cold start for around 10-15minutes before I took off.
Other times, It had been a at least a good 10minutes of driivng before I actually tried it.
I actually thought it would have been spark plugs or air intake. Maybe something's inside the intake?? perhaps blocking some airflow @ high rpm?
But i'm replacing the plugs first to see what happens; which is partially why i signed in for group buy
And yes; its a GPX
And yes; its a GPX
- demonic_hordes
- demonic_hordes
- demonic_hordes
come to think of it, it only really happens when i change gears. therefore, i am now convinced its the tiptronic that is acting up. out of sync maybe?
when i drive normally with tip, sometimes, i can see the light on the dashboard change gears but it takes another...second? for the engine to actually change. ie, the light changes gear for we actually see the engine do this.
any suggestions/
any suggestions/
- demonic_hordes
read the link few more time,demonic_hordes wrote:well, i've read the site many times, but i don't seem to see what would happen if the sensor is dodged. if its acting up, would it not light up on the dash when i earth the diagnostic control? or what would happen to let me know its dying?
or, is this to simply clear all the codes
The appropriate light will start blinking which will give you the error code.
No blink, then all good, find another way of diagnosing
yes blink, eg: abs light, slow, slow, slow, fast = error code 31, which means left rear spped sensor not working,
Check the code against the workshop manual
