different idle problem after new stepper motor
- mivecboy
I ve replaced my stepper motor few weeks ago due to idle die out when cold and when aircon is switched on.
This has fixed the problem but I'm experiencing another 2 issues:
1) idle will bounce up and down between 900 - 1600rpm when doing half to full steering turn whether stationary or moving.
2) When cold start, idle is very high at 2500 - 3000rpm for few minutes, then it would bounce up and down between 1500 - 2100rpm for another few minutes before it settles down to normal idle rpm. I remember back when my old stepper motor was working properly, cold start did not go above 2000rpm. So reving at 3000rpm when cold is not doing the engine any good. What does your FTO revs when cold?
I've resetted my ecu twice with no cure to the above problems
please advise?
please advise?
Sounds like that stepper is a bit dodgy... did you buy it new? It also might be the TPS unit (throttle position sensor.) Its the black plastic housing bolted to the front side of the throttle body. I'd suggest removing it & carefully cleaning it & putting it back on. Alternatively you can actually adjust the TPS using this guide:
http://www.ftooc.org/phpbb/viewtopic.php?t=45401
- know1here
- SG
Re: different idle problem after new stepper motor
i've replaced my stepper motor with a new one awhile ago and have been getting that recently.. its a prob with the air con unit, or something. theres no probs with idle at all when the air con is turned off when i start the car or turn it off just after starting it. sounds like the car is miss-firing though if the aircon is on. (running on 2 or so cylinders)mivecboy wrote:I ve replaced my stepper motor few weeks ago due to idle die out when cold and when aircon is switched on.
i get the idle bounce aswell when turning but i'm told thats normal as the motor wants to keep the revs up, to stop leaning out on corners or something, but i'm not sure about that.. its not a direct injection motor but i dont think it'll stop receiving fuel if you turn suddenly
have you tried resetting / training the ecu with the aircon off?
- SchumieFan
- khunjeng
only needs 100kms accoring to the sevice manual. I have done it heaps and seems to work itself out after 50-70kms...bigpitty1 wrote:that what happened with mine, in 2 weeks it was fine again, it probably took so long coz I only drive my FTO on the weekend.
so if it hasn't fixed up bu 100 u have another issue.
dod u check the TB and the TPS??
- Storm
When you switch on your air con the revs rise because you are running an extra pump so the engine compensates for this by giving a little extra power.
Now here comes the technical bit so pay attention.
When you turn the steering wheel the power steering pump kicks in so the engine is running an extra pump and compenstes by giving a little rise in revs to bring some extra power.
Simple really
Simple really
- mivecboy
Thanks Storm.
But this bouncing rev is very annoying at its bouncing very high to 2000 rpm sometimes when turning! this is kind of dangerous when im doing a slow corner. Same goes for my air-con when switched on. My old stepper motor never rev this high when idle, so do I hv a dodgy stepper (I was told its a new replacement) or if there is adjustment I can make to fix this?
- Storm
I'm not sure about the bouncing, 2k does seem a bit high. The inly experience I have had with bouncing revs was it dropping at 30mph. That was the TPS which needed reseting and theres a write up on the UK FTOOC about checking it. You will get it by clicking heremivecboy wrote:Thanks Storm.
HTH
Storm
- bigpitty1
