Tip Box
- CraigNZ
Tip Box
For the last two mornings my car has refused to change up, after the revs climb it suddenly 'bangs' into third and the neutral light starts flashing. If I stop and restart the car its OK
This serious or is it time to change the fluid and do an ECU reset ? Have had the car 18 months and do not know when the gearbox oil was last cahnged.
Thanks
Thanks
- kazbah
- National Secretary
I would say serious..... the N light flashes when the computer puts the car into "limp" mode to prevent further damage to whatever part is playing up. Do an ECU error code readout and see what it comes up with
But definately start with a gearbox oil change.... Have you looked at the level or state of the gearbox oil.. check the dipstick.
- SchumieFan
- khunjeng
- Storm
My car had this problem that it would not change up from second to third unless you were under about 3K rpm. It was the torque convertor which here in the UK is about £100. I have still not been given any satisfactory explanation of why it does this but a few owners here have changed the TC with good results.
However none of us were getting any error codes from the tip box so check that out first.
HTH,
Arashi
HTH,
Arashi
