Damn key got stuck in the ignition!!!
mxysxy
Post by mxysxy »
Better start searching the forum then,
bigpitty1
Post by bigpitty1 »
sounds like the ignition barrel is broken.
If its tip, then its likey to be the cable that runs from the barrel to the tip lever. There's a little plastic lug that it moves behind the barrel. Do a seach you'll find it - if not here then on ftooc :wink:
kazbah
National Secretary
Post by kazbah »
Try taking it outa park (if its a tip) and pushing it back in pretty firmly... worked for me :wink:
Teania
Post by Teania »
kazbah wrote:Try taking it outa park (if its a tip) and pushing it back in pretty firmly... worked for me :wink:
Yep, that worked for me too ..... to start with
Then it got REALLY stuck, took the silly bit of plastic out (well - actually it fell out as soon as we opened the housing up) and no more problem.
If yours ever gets stuck Kaz - give us a hoy, Roberts had practice fixing this 8)
