DBA Slotted Rotors - CHEAP!
- idawina
hi, i have a set of DBA Slotted brake rotors for sale. Heres the catch - they are exactly the same dimensions as FTO GPX rotors but are 4 stud ( to suit galant vr4) a friend of mine who is a machinist says they can be re drilled to 5 stud to suit fto's. All rotors are BRAND NEW, never been on a car.
Dba 402's front slotted vented rotors, cost me $170 each, sell $200 pair
DBA 416's rear slotted rotors, cost $110 each sell $100 pair
pm me for more details.
they are located in tasmania. freight extra.
- poster
Re: DBA Slotted Rotors - CHEAP!
u sure when u can drill those things ? wont it bent the rotors while doing it ? if im not wrong one little bent can make a lot of difference...idawina wrote: a friend of mine who is a machinist says they can be re drilled to 5 stud to suit fto's.
how much wil it cost to do this and where can i get this type of service ?
thanks
Any good machine shop can do that for youposter wrote:u sure when u can drill those things ? wont it bent the rotors while doing it ? if im not wrong one little bent can make a lot of difference...idawina wrote: a friend of mine who is a machinist says they can be re drilled to 5 stud to suit fto's.
thanks
- SILVERFISH
- VIC Coordinator
Where and what kind???
Where and what brand/model???
- idawina
Are these the standard DBA rotors that are slotted? DBA slot it themselves, From dba website, which cost $120 rrp each for the front.idawina wrote:these are brand new, still in the box. And asking $300 for the set.
yes drilling is fine, welding/heat is what warpes rotors!
they are DBA Brand, standard slotted series. not the cheap ones that warp as soon as you press the brake pedal!
they are in Tassie
Or is it some other series?
- Nickname
- to4garret
