GPvR Bushes...
frozenwaffles
GPvR Bushes...
Post by frozenwaffles »
Hi Guys, all my suspension has started to creek and groan something cronic. i think its time i replace all my bushes underneath...
however, i have been to camskill.co.uk and there is heaps of bushed listed but a lot are for all FTOs except GPvR!!!
Firstly where do i get bushes in sydney and what are the part numbers i need for my GPvR???
Appreciate the help...
Mate, you still have that bent lower arms?
Most of the bushes are the same except for the lower control arm rear bush, its a much better fitting unit.
But I'd like to get that arm to make sure.
Ju5tin
Re: GPvR Bushes...
Post by Ju5tin »
frozenwaffles wrote:Hi Guys, all my suspension has started to creek and groan something cronic. i think its time i replace all my bushes underneath...
I'd assume it would be identical to the GPX at least.
frozenwaffles
asumptions are the key to all fuckups....know this people!
After research i have found they the sway bar bushes are posibly different and the rear bush on the front lower control arm is special too.
Ju5tin
Post by Ju5tin »
frozenwaffles wrote: After research i have found they the sway bar bushes are posibly different and the rear bush on the front lower control arm is special too.
Yeah? Hmm .. That still doesn't sound right to me. I was pretty sure the GPX and the GPvR is identical in that area. Hmm :?:
Nah its not...
The rear control arm bushes on the front of the car are quite different. The GPvR ones are much better... a press fit bush in a metal casing. Where as the GPX / GR have this big rubber blob that sits in there...
GPvR Bush
GPX / GR Bush
Ju5tin
Post by Ju5tin »
Oooh .. At least it's a big RED rubber blob. :D
LOL damn right! :lol:
frozenwaffles
well at least they will go better with your car bennoz...
oh yeah do you work for fujitsu by any chance?
