Battery on 10V
sublime19
Sooty!
Battery on 10V
Post by sublime19 »
I noticed when I started the car today, in idle while I was leaving my engine oil to warm up it showed the battery at about 10V, and the second I started driving it was back to normal at a healthy reading and stayed there whenever I stopped at the lights etc.
I'm guessing this has something got to do with the cold weather? as it stayed normal once I started driving
scarecrow
Post by scarecrow »
8O I guarentee you that if you havn't recently fitted aftermarket dials then something has gone very awry.
If you've got a multimeter test the voltage drop across the +ve and -ve terminals with the car off, with all accesories turned on, at idle, and then at idle with all accesories turned on.
Chances are your battery's about to cark it (which wouldn't be to bad, cheap) or something more expensive is on it's way out.
While the car is started it should not, ever, sit to far below 12v.
sublime19
Sooty!
Post by sublime19 »
hopefully its just the battery then 8O
I noticed once before when I was driving, with the air con on, once I stopped at a traffic light, on idle the battery kept going to 12, then back up, until i started moving.. and the needle would keep moving back and forth slowly when I stopped again :?
You an NRMA member Devesh?
khunjeng
Post by khunjeng »
checking the battery under no load wont prove much...but if its low under no load I doubt it would even start.
test it with the car running and see whats going on. Mine drops a bit also at the lights I notice...I suspect the alternator...just rev it a bit and see what happens...I mean only up like 200rpm.
sublime19
Sooty!
Post by sublime19 »
Bennoz wrote:You an NRMA member Devesh?
I could be for the low price of $8500 per year :lol:
Maybe i should get my battery changed.. rather that than having it just die out when I'm out somewhere.
I'll check to see if it happens again tomorrow morning, if doesn't happen again then maybe it was just a one time thing.. I hope
NRMA membership is $50 a year... this is the kinda thing you'd have diagnosed in 10 minutes & a new battery (if thats the issue) for $100... delivered & fitted at your front door :wink:
sublime19
Sooty!
Post by sublime19 »
8O
I never new that?! I'm assuming you're referring to roadside assistance? gee.. I'm gonna sign up tomorrow! :wink:
khunjeng
Post by khunjeng »
arn't u under 25 ?? hehe it will cost u like 4k a year. hehe
sublime19
Sooty!
Post by sublime19 »
lol now i remember my dad telling me it was like $45 a year at one point, I didn't pay attention to him :?
I don't think they'll add $3950 on top of the $50 just cos I'm 21 :P
khunjeng
Post by khunjeng »
don't put it past those bastards...
scarecrow
Post by scarecrow »
Haha, roadside assistance is pretty much the same for all ages :) Ranges from like 45 to 95 depending on the type of cover you're after.
Mines been pretty useless though... having said that, it's not a lot to pay to have your ass covered in the event of a major breakdown half way between sydney and the top of queensland however.
Breza
Post by Breza »
Do they stock Optima Yellow Tops? :-)
Chris
sublime19
Sooty!
Post by sublime19 »
ok this happened again today when i started up my car until i started driving.. something is going wrong, im gonna sign up to roadside assitance
Ju5tin
Post by Ju5tin »
khunjeng wrote:just rev it a bit and see what happens...I mean only up like 200rpm.
Or perhaps you mean 2000rpm's. :D
Sorry. I'm so cheeky.
Gpx_xxx
Post by Gpx_xxx »
Im 18 and i got NRMA road assistance i only paid like $100+ for a whole yr. and yeah i get that too sublime when i put it on idle its like below 10V scary lol
sublime19
Sooty!
Post by sublime19 »
ah well im not by myself lol..
khunjeng
Post by khunjeng »
no 200...just a slight increase in throttle...see if it restores.
Ju5tin
Post by Ju5tin »
khunjeng wrote: no 200...just a slight increase in throttle...see if it restores.
Ahh .. I figured you were saying to rev it TO 200rpm which wouldn't really make sense. I know what you mean now. :D
insanelin
Post by insanelin »
hey guys..i just reconditioned my alternator 2 mths ago and replaced a brand new battery with RACQ but there are a few things i spotted on my battery gauge.
1) After the first turn of key, the needle will go pass 12V
2) After the engine is on, it almost reached 16V
3) However, when the car is running, the needle drops back to 14V region
Any bro experienced this problem as well?
Cheers
