Filter.. please help...
- lawrencetlc
What kinda filter can i get from K&N?
Is it a good brand? Heard many people using that.
Do I need to do any mod to the piping? or rather just a "plug and play" thing?
Thanks.
Thanks.
- sublime19
- Sooty!
Well having a pod filter only won't do jack sh*t unless u have a bigger pipe for air flow (as i've been told by Bennoz) which is pretty cheap, u'll get a minimum 2kw at the wheels or 3-4 if u have a mivec - this is for manual not sure abt auto
- sublime19
- Sooty!
that's what the muffler is mainly forJu5tin wrote:And the best thing about the Filter is not just the few kilowatts, but the Induction noise.
- khunjeng
the induction noise is awsome on the fto...
I like the Unifilter setups...and I also have the UAS intake pipe...lots of posts on these - do a search.
you will need to box it up to get any gain...most of the gain is from replacing the stock intake pipe...not so much the pod but it sure sounds great...
- lawrencetlc
Do you mean that by changing the filter box i'll get a different sound?
What sound is that? sounds cool~~
What kinda piping i have to get? Do I need to custom made the pipes or I can just buy aftermarket? Because there's very limited space in the engine bay right...
Oh, yeah, by the way, mine is mivec manual.
Thanks
Oh and also, the reason I mentioned about K&N is because I got an email from autobarn saying that they got sales for k&N filter and it costs only 70 bucks...
By the way, what is the normal market price of a filter?
This is the link...
http://www.chadstone.autobarn.com.au/ht ... d=1254#Top
Thanks
This is the link...
- khunjeng
u don't need to clean them? highly doubt that they are filters and their job is to catch crap.jonowong wrote:$100 for apexi one... theyre better because they keep the engine cleaner and also you dont need to clean them unlike the k&n
there are a number of types of filters (not brand) to look out for:
Paper (usuually the stock filter type)
Oiled Paper
Cotton Gauze (K&N etc all ususally reside in this bracket)
OIled Foam (similar to Unifilter)
Oiled foam is less restrictive than paper, and can have much higher filter properties which generally means they ahve a large surface area...they also need to be mainatained i.e. re-oiled every say 15,000 kms
Instresting to note that that Cotton Gauze is less restrictive than Paper but has poorer filter properties than all of the above types...so in reality...the K&N type is letting bigger sized dust particles into your engine...
I have more info on this is anyone wants it.
- lawrencetlc
- Nacho
- SugarFreeGum
- sublime19
- Sooty!
hks ftw!!jonowong wrote:but theres a site with testing that says
apexi wins... k&n is 2nd... and hks is last... and theres some other ones in between
- lawrencetlc
hey guys..
i went to repco today, and was going to get a filter. however, there's some cheap filter with 34 bucks available and also k&n for 70 bucks. from the outside, they seems quite same to me, but the shopkeeper told me that they use different material for filtering..
then i brought both out to my car as my car was just parked outside, and try to fix them to my car... However, even when i manage to fix the cheap stuff to my stock pipe, there's no much difference in the "suction" sound which i expect to hear it...
I didnt manage to fix the K&N one because it is not fitted..
So, just wanna ask whether i have to get the pipe changed with the K&N filter? and also, if i just changed the air filter, does it produce the cool suction sound? Which RPM is the best to hear it?
Sorry for being noob here...
thanks!
thanks!
definetly go the K&N.
You will get a big performance boost if you change the piping over.
There are several different choices you can make. I have a stainless steel pipe that looks wikkid!
You will REALLY notice the difference when your driving down the road and hit the MIVEC kick in point around 5800 rpm.
- lawrencetlc
