18x8 rims?
RedlineGX
18x8 rims?
Post by RedlineGX »
Just wondering if anyone had on any 18x8 rims and if they had a problem with rubbing on the front inner shock? Offset is 42. Will be on 215/40/18z cause 35 is too little rubber for me. Rims are here already so if they dont fit will have to get coilovers and dont have the money right now :cry:
Im running 18x8 with a 225 & yeah it did rub a tiny bit on the underside of the strut. A little bit of heat, a little bit of hammer gave me the few mm I needed for clearance... plus pulling out the camber pins....plus 3mm spacers lol
SG
Post by SG »
offset of 42 is a bit high
i was gonna get something like a offset of 30-35 to use 8" rims and 235/40/17 tyres with.
though thats because i have about -2 to -3 degrees of camber and the standard wheels rub as it is on full lock :) :roll:
if you have zero/neutral camber it'll help heaps
RedlineGX
Post by RedlineGX »
Ok thanks guys. Think I might as well save and get some Teins. Btw Bennoz do you know the offset of your wheels? Yeah I know 42 is high but its the lowest i can get in the wheels i like and I'm trying to avoid spacers.
