At what size is the TB too big for a 6A12?
I am thinking of cutting the plenu, getting rid of the twin length butterflies, welding a new plenum on, with the match ported and shortened runners and using 48mm TB per side of the plenum
Thoughts?
Throttle body sizing, twins?
- spetz
- SG
affects drivability heaps if you have too many throttles afaik, duno the limit though, you could get 6 pack throttles but you wouldnt have a bottom end rev range
a guy i know has had 4 pack throttles and vowed never to go back because the car was undriveable below ~3k rpm. not sure what he meant by undrivable, maybe it would stall due to low vacuum or something while on load.
- Dras
little bit a math for yal
area of a circle = pi * r * r
for 48mm the area is 1809 mm squared
if you have 2 you get 3619 mm squared.
This is the same as a single 67.88mm throttle body.
Unless you can get this mod done real cheap I would think a 65 mm or 70 mm single throttle body to be a more economical mod.
