ticking/clicking from the glovebox?
noccers
Post by noccers »
This morning I turned the car on and the glovebox area started making a really loud clicking/ticking noise. I'm pretty sure the ECU is behind it so would it be coming from that, and what the hell does it mean?
The car hasn't changed in performance at all, it all seems to function and operate as per the norm, except for that one thing.
It clicks about 124 times if my counting is accurate. Really confused as to what it could be, but car is off the road until i find out.
Any help is appreciated!
gawk; talk; date; wine; grep; touch; unzip; strip; touch; gasp; finger; gasp; mount; fsck; more; yes; fsck; gasp; eject; umount; make clean; make mrproper; sleep;
successful trades: d_stroy_r, shue, mxysxy, dstocks
mxysxy
Post by mxysxy »
was air con or fan on?
BorepYano
Post by BorepYano »
rofl, u sat there and counted? lol
maybe u have a bomb in your glove box lol
um.. if its the ecu making the noise then your car wont move, ecu = no moving parts, if it's making "clicking noise", then that's short circurting and trying to set fire to your car, so if u sat there and counted it without being burnt to a crisp then it's probably not that... (well might not burnt to a crisp cos a fire wont start unless there's an accelerent there to fuel it, but u'd be able to smell plastic burning)..
apparently a few ppl on here had similar problems as to what u said, and they always come to the same conclusion: aircon/vents, so check that :)
Edit: bah, max already got to this oops
noccers
Post by noccers »
it's not aircon vents, nor is it short circuiting. It's not a tapping noise like mechanical parts hitting eachother. I counted because it's consistent; it happens only when i turn the car on, counts about that many times then stops and never comes back.
This lead me to suspect it was some kind of error diagnostic number, however I'm unable to find any information to suggest it, or of anyone else having the same problem.
noccers
Post by noccers »
When I say, 'turn the car on' I mean, turn it to accessories. The car doesn't need to be started for this to occur. However, it will reset when I start the car, because power is reset. Just as it resets if I turn it to off then back to accessories again.
These are more reasons I believe it's some kind of error warning, but I could be wrong.
noccers
Post by noccers »
mxysxy wrote:was air con or fan on?
Nope.
Try changing the climate control airflow from recycled to fresh and see if the sound stops next time you hear it (even if the climate control is off).
noccers
Post by noccers »
Supplanter wrote:Try changing the climate control airflow from recycled to fresh and see if the sound stops next time you hear it (even if the climate control is off).
Well, I hear it every time, but I'll give it a go now :s
noccers
Post by noccers »
Right, this convo is now locked LOL :lol:
that was odd, but it seems to be fixed. I tell ya it scared the crap outta me. I assumed cos it was off it wasn't that :oops:
khunjeng
Post by khunjeng »
from memory there is a noise when you switch it on...I never worried it seems to be the c/c
BorepYano
Post by BorepYano »
a little drunk right now
so the climate control thing fixed it? :?
btw, 124 clicks... lol imagine a mechanic trying to figure out what the problem is with that...
"120... 121... 122... 123... arrhh crap i lost count" :)
noccers
Post by noccers »
BorepYano wrote:a little drunk right now
Imagine an auto elec trying to figure it out from the engine light flashing. Yeah, really impossible ... :evil:
cb
Post by cb »
I bumped an old topic I know but atleast i did a search :lol:
My aircon does the same ticking probably 124 times too and then stops and also stops when i change it from recycled to fresh air
so I can stop it by hitting the recycle/fresh button
But how do I really fix it so i can have it on recycle without it making that annoying noise?
any guides or anything
cheers
My car still does it. It is the motorised vent that switches between recycled and fresh air for the climate control; I think it gets jammed or the motor doesn't know that the vent is closed and keeps trying to close it. It looks like a bitch to get to, from memory you have to take the whole dash out... so I just put up with the clicking or switch it to fresh air when I get in the car :roll:
Here are the relevant pages from the workshop manual if you are interested in trying yourself:
BorepYano
Post by BorepYano »
this isnt much for the topic, but thank you SOOOOOOOOO MUCH for the blow up of the dash, been wondering about which bits are supposed to be joined up which bit are supposed to come apart for ages now lol
thank you :lol: :lol:
cb
Post by cb »
yeah wow stuff it I don't even care anymore haha. thanx for your help!
Jono
Post by Jono »
mmm ive got the same problem.. :/
Jono
