Moderators: IMC , Club Staff
kermut
Posts: 356 jedwabna poszewka promocja
Post
by kermut » Sun Apr 22, 2007 3:34 pm
can anyone help me out with my friends lancer 4g93 turbo hes oil light won't turn off. thanks guys
SILVERFISH
VIC Coordinator
Posts: 1384 Joined: Mon Jan 16, 2006 6:00 pm
Post
by SILVERFISH » Sun Apr 22, 2007 5:29 pm
put oil in it
Camo
Posts: 382 Joined: Sun Apr 17, 2005 5:00 pm
Post
by Camo » Sun Apr 22, 2007 11:34 pm
lol pwned!
BorepYano
Posts: 4609 Joined: Sat Aug 12, 2006 5:00 pm
Post
by BorepYano » Mon Apr 23, 2007 12:55 am
or u can take the fuse out
T_T' we r so helpful lol
kiz wrote: silverGPX wrote: This requires a thread? lol
jonowong
Posts: 3420 Joined: Thu Jan 15, 2004 6:00 pm
Post
by jonowong » Mon Apr 23, 2007 1:45 am
check the error codes!
i know when u turbo a non turbo car... u sumtimes get an engine check like because the MAP sensor doesnt like boost
eThix
Posts: 1046 Joined: Mon Feb 12, 2007 6:00 pm
Post
by eThix » Mon Apr 23, 2007 9:56 am
S1LVERFISH wrote: put oil in it
lol did you check if your oil is low? cause he might be right
Posts: 5875 Joined: Thu Aug 05, 2004 5:00 pm
Post
by SchumieFan » Mon Apr 23, 2007 11:04 am
dirty sensor? trace it and clean it.
or broken wiring maybe...
check error codes or trace the wiring.
FTO338
Posts: 6712 Joined: Sun Feb 09, 2003 6:00 pm
Post
by FTO338 » Mon Apr 23, 2007 2:38 pm
What type of oil does your friend use Kermet? I had this experience when i put some engine additive into two different car and the engine lights turns on every now and then. Some senor on cars are dam sensitive.
So it could be the type of oil your mate is using too.
bigpitty1
Posts: 629 Joined: Thu Mar 18, 2004 6:00 pm
Post
by bigpitty1 » Tue Apr 24, 2007 10:16 pm
check for codes, the oil pressure sensor has probably died, its common for the holden GEN3 5.7l V8 oil pressure sensor to die and they usually set a oil pressure sensor high voltage code, if its not that oil level is low or the oil pump is dieing.
kermut
Posts: 356 Joined: Thu Nov 24, 2005 6:00 pm
Post
by kermut » Fri Apr 27, 2007 5:11 pm
thanks guys found the problem it was the wiring in the car all good now thanks again guys
Post
by SchumieFan » Fri Apr 27, 2007 7:08 pm
hahahahahaha
i love it when im right
a) doesnt happen very often,
b) makes me look smart like
