Just a random question.......
What would happen if the transmission fluid in a tiptronic box were to get really hot?
Or long story short.....the radiator in a tiptronic has a cooling line for the tranny fluid.....any thoughts on whether you really need to cool the tip fluid down via the radiator or would it be ok with a little airflow?
Transmission Fluid At High Temperature
- Nacho
- phunkydude
Re: Transmission Fluid At High Temperature
Same theory as your engine oil.
Once you cooked the oil, it lost its' lubricant effect thus damaging your gearbox.
One extra thing on auto/tip-box is that when you got a boiling atf flow through your torque converter, it's gonna blow it.
- Nacho
Lock it in Eddie........pm sent
- payaya
Heat in auto boxes is number one killer of them. The cooler the better.
I've got this and my tranny has not run better.
http://www.bmracing.com/PRODUCTS/Automa ... 11x6x1-1-2
