Like I was telling you the other day, if you don't wanna spend much money on your current car, just buy some sealant and smear it along the whole gasket and tighten the bolts tighter.
You even need to use the sealant in the corners of the outer cam caps on a brand new gasket. Or do what Phil did and use a whole tube on a brand new gasket.
Vectose wrote:If you use some Ultra Blue or similar it will never start leaking again unless you take the cover off. Will be perfectly fine to sell with it as well.
I see....
To supercheap auto!
Vectose wrote:You even need to use the sealant in the corners of the outer cam caps on a brand new gasket. Or do what Phil did and use a whole tube on a brand new gasket.
I didn't use a whole tube
I just put a bead all the way around, top and bottom.
That tube done heaps of sealing on the Vectra, my FTO and the FTOs on the DIY tappet day.
