Wheeeeeee! A big box marked with FUNKY PRODUCT has just arrived at my door! New V3 Gauges, Type R Pedals, Clear Side Indicators, & Carbon Fibre Gauge Surround! YAY ME!
Now before I go charging into the garage, spanners & screwdrivers flailing wildly... Has anyone who has installed any of these items had any issues with them?
If I Had A Dollar For Every Time Someone Said "If I Had A Dollar For Every Time Someone Said <...>" Well... Then... I'd... Have A Dollar For Every Time Somone Said "If I Had A Dollar For Every Time Someone Said <...>"!!!
be careful with those v3 dials. ive got mine sittin in a box me being to chicken to try and fit them and send me a pic of that carbon dash surround once its fixed
Gauges - Just be careful with the needles and you should be ok.
Pedals - Simple enough - I opted for Sparco screw ons that you have to drill holes into the pedal itself. a lot harder to fit but once they're on they're on for good. Not sure what you have but usually farely obvious.
Side indicators - Easy to fit but sometimes a bit loose. Never had trouble with mine but you might feel safer putting a little clear silicone on the inside to fit it securely.
Gauge Surround - Piece of cake. I reccommend some thin d/s tape or a few small dabs of the same silicon to keep it in place.
Is fairly fiddly. The instrument surround will give you no grief - simply slips in (I think its the same as mine although mine is stainless steel). Do this at the same time as the gauges.
Well doesn't look like i'll be fitting them any time soon, need to get a new 3 new cabinet for my place.
Ooooh! Pretty... Okay that Walkthrough will come in handy... Okay, I'm off to do this... *crosses fingers*
Okay... Im having issues with the Tacho... Adjusting it is a bitch! HOw far am I supposed to be pulling it out! Im turning it and it's just springing back into place! I'm going to pull stuff out again... Have to check my Fuel meter connection & Volt Meter connection... They seem to be off! Anyone got any tips for these?
Okay... Fuel Meter & Volt Meter sorted... Still not sure about the Tacho... I'm pulling on the needle but it ain't budging! I'm afraid I'll break it if I pull any harder HELP!
Other than that... THEY LOOK FREAKING SCHAWEET!
I'm an absolute nervous wreck over this bloody tacho
Hee hee... All finished... Looks freaking schaweet! And as an added bonus... IT ALL STILL WORKS!
Will post pics soon...
Yes... Used the guide, fantastic reference - No need to change it!
Pedals are on now too They look that good I'm sure they must add Kw! Hee hee...
Clear side indicatiors are a MASSIVE improvement over those horrendous orange things!
